R randerson165 Senior Member Nov 7, 2003 #1 I need a knock sensor for a 99 civic asap. I need to pass DEQ and I can't do so untill I get the knock sensor replaced.
seanjuan Senior Member Nov 7, 2003 #2 what kind of car? what engine? do USDM civics even have knock sensors? are you sure your knock sensor is bad and not the wiring?
R randerson165 Senior Member Nov 7, 2003 #3 I have checked continiuty on the ECU and the wire running from the ecu to the knock sensor and its good. I just need a good knock sensor.
R randerson165 Senior Member Nov 10, 2003 #5 Does anybody know where I could look ? There not on ebay and a salvage yard won't give them up without taking the whole engine.
R randerson165 Senior Member Nov 12, 2003 #6 come on, somebody has to have one. They come on numerous engines, not just the d16y8
