wtb MAP sensor for JDM B16A
Discussion in 'Parts: For Sale/Trade/Wanted' started by alldriverSiR, May 6, 2004.
  1. alldriverSiR
    alldriverSiR Member
    Looking for a MAP sensor for a JDM B16A throttle body...
    Also can I use any map sensor as long as its's OBD0?
    thanks
    steve
  2. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    my buddie has the same motor and i gave him one off my obd0 ls and his is 0db1. and it worked
  3. spaceman
    spaceman Member
    is your map sensor on your throttle body?...do you have a pic?
  4. alldriverSiR
    alldriverSiR Member
    my map sensor is located on the throttle body...i used my stock vacuum setup from my EF setup....all i did was drop in a jdm B16A....
