WTF: D16A9 Parts??
Discussion in 'HYBRID -> ED-EF / DA' started by fontaracing, Jan 8, 2007.
  1. fontaracing
    fontaracing New Member
    Lima, PE
    Hello,
    im looking to rebuild a D16A9 engine but i can´t seem to find parts for it. Can any of you provide any link for parts.
    Also I would like to know what parts are interchangeable in the D16Ax series?
    thanx
    Fonta.
  2. fontaracing
    Lima, PE
    Anyone? Come on!!
  3. 801CRX
    801CRX Got Rice?
    UTAH
  4. fontaracing
    Lima, PE
    hello 801CRX
    even parts from SOHC and DOHC? Pistons? Valves? are interchangeable
    thanx.
    Francesco
  5. 801CRX
    801CRX Got Rice?
    UTAH
    From my knowledge yes, even ZC parts and the ZC is also DOHC
    USDM and JDM parts are interchangeble.
  6. jlicrx
    jlicrx Senior Member
    Colorado Springs
    parts for the D16A9 - everything below the top of the block is the same as the 88-91 CRX/Civic D16A6 - everything above the top of the block is the same as the 88-89 Integra D16A1 - the only exception to this is the timing gears and belt - the timing gears on the crankshaft and camshafts are DOHC ZC, D16A8, D16A9, D16Z5 only - the camshaft timing gears for a B-Series engine will work, but the timing mark on the exhaust cam is one tooth off - the timing belt is the same as 88 Prelude 2.0 SI
