Wtf--hood Help?
Discussion in 'General Tech and Maintenance' started by JDMilan, May 27, 2003.
  1. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    Ok, this shit is killing me. First off, I tried to pop my hood and the cable came off from inside my car, next I tried to pop the hood by pulling the cable from underneath the car. Then it came off. Then I took a damn crowbar and tried to pry the hood up (reason is I have no brake fluid and my brakes don't work, long story) Now I am getting impatient. I also hate my fucking ride. So the hood is dented up and looks even worse. My Q is "how the fuck do I open this fucking hood" thanks.
    Milan :angry:
  2. JDMilan
    Boca Raton, FL
    TTT
    Milan
  3. IDMaxGuy
    IDMaxGuy Senior Member
    MO
    Plasma torch...... j/k call a tow-truck place there good at breaking into things, get a piece of metal kinda like a cloths hanger, and hook one end then get up under the car and try to work the latch.... sorry i cant help ya, personally i would just jack the bitch up and start dissasembling things from inside until i got the hood off.(ignore my previous statement)
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    is the cable brken off the latch in the car or at the latch on the hood
  5. E_SolSi
    both
  6. hcivic.com
    then all you can do is cut the hood off a die grinder adn about 6 inches around the latch have fun
  7. JDMilan
    Boca Raton, FL
    I will keep you guys posted on what happens, later today you should hear of some results...........i really don't want to bust out with my crowbar again.:bash:
    Milan
  8. kingwilly
    kingwilly Senior Member
    arizona
    its basically a hook thats in a hole...if you can get a thin screwdriver maybe have someone lift the hood while you push on the hook..i dont know what year hood you have
  9. machine
    machine Banned
    houston tx
    yeah try lifting the hood and working it with a screwdriver, maybe youll get lucky
  10. JDMilan
    Boca Raton, FL
    going to try now, I will keep you peeps posted.
    it's an EF dx , I hate fucking EF's
    Milan
  11. Jeef
    Jeef NO MA'AM Moderator VIP
    EF's own joo
  12. JDMilan
    Boca Raton, FL
    Ok, got the fucker off, the front of the hood looks like someone hit my ride :) it's cool, getting new project EG soon. Anyways, I had to lift it high enough to take the bolts out that hold the latch in place, I was working with about 1 inch of space. So it finally came off and I ended up fixing my brake booster, then came the problem of removing my AC and old radiator (i needed a new radiator anways but while i was trying to open the hood up I fucked up the radiator to the point that it started to leak everywhere, a little afro engineering never hurt) so I took the entire AC system out along with the radiator and I am waiting on a new brass end tank radiator currently, should get it tomorrow or friday. Thanks for all input fellas.........
    Milan
  13. JDMilan
    Boca Raton, FL
    Ok picking up this tomorrow then, will be posted soon
