WTH is this?
Discussion in 'General Tech and Maintenance' started by efhondakid, Jul 14, 2008.
  1. efhondakid
    Akron-Canton, Ohio
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    That's HUGE!
  3. HelixB18C1
    HelixB18C1 Member
    Dallas Tx
    sounds intresting. any one know if this works?
  4. brian11to1
    brian11to1 Senior Member
    That's a spool. Not a limited slip differential. Spools are best for high power drag cars that do not see the street.
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yep..and they work great..intended for straight line
  6. SlushboxTeggy
    New Jersey
    That's what she said........
  7. HelixB18C1
    HelixB18C1 Member
    Dallas Tx
    damn why didnt i catch that one.
    so does this contraption work?
  8. TurboMirage
    looks about right. you bolt your ring gear onto it, and it turns both axles at the same time.
  9. newb
    newb phresh VIP
    Backwoods Northwest
    Lol, if your runnin slicks you better make sure your steering colum can support your body weight, cuz when your drivin through the pits and wut not your gunna hafta hang your self off one side of the steering wheel to turn.
    1 person likes this.
  10. HelixB18C1
    HelixB18C1 Member
    Dallas Tx
    so this isnt for a daily driver correct?
  11. newb
    newb phresh VIP
    Backwoods Northwest
    It wears tires super fast, makes steering a bitch (if you have power steering itll drasticly decrease the life time of the pump), and it will put huge amounts of stress on everything between the wheel and differential. But, if you dont mind decreased steering capabilities and replacing parts often you can DD one of these.
  12. Ethan
    Ethan Well-Known Member
    woo hoo ima drop one in my accord to make it turn better! :D
  13. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    that has shady all ovet it, it looks used and if i remember right the gsr and the b16 is different
  14. brian11to1
    Unless you only go in a straight line... then no.
    SPOOL = STRAIGHTLINE
  15. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Hense the "not for street use".
  16. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    a spool no, not for street use , but hey we do all kinds of stuff to our hondas thats not really for street use ,
  17. phunky.buddha
    Dallas / Fort Worth, TX
    Suspension and exhaust that's "for off-road use only" is totally different from a spool that's "for off-road use only" and makes your car next to impossible to turn! Other "non-street" parts don't make the car undriveable!
  18. 97DXcoupe
    97DXcoupe GSR Swapped/Gutted
    zinger right there..
  19. 97hatch
    97hatch ?
    Anderson IN
    b series diffs are all the same the only difference is some cable diffs have a 110mm ring and all the rest is 114mm or 117 i cant rember its one of the two
  20. HelixB18C1
    HelixB18C1 Member
    Dallas Tx
    Justin, Half of the parts on my car say in BIG BOLD LETTERS (NOT FOR STREET USE)
    Nice avatar. It reminds me of an integra listening to and i pod for some reason.
