NY Wtt jdm clusters
welfare
Ancient Member
WTT JDM ITR cluster that I have (converted to work in obd1 integra, INCLUDES ALL OF THE ORIGINAL STUFF TO PUT IT BACK TO OBD2
for
YOUR eg6 cluster
the ITR cluster is genuine and has a clear cover, no heavy scratches or discoloration or anything out of the ordinary amber lighting, no broken tabs or mounts etc.
it has 100868 kilometers on it, it had 60 when I got it, it works fine, and the way it sits it will plug right into your 95-95 integra, MAY plug and play right into 96-97 integra, has all of the componants that came with it all installed into the other cluster, so if you have obd2 98-01 integra you can just swap out the bezel and the gauges to the other pcb/backing and it will work just fine.
civic eg6 cluster has to work mileage doesnt matter must be amber lighting.
Let me know
Aightball@aol.com
