Wutz the difference between the P05 and the P06?
Discussion in 'ECU's, Electronics, and Tuning' started by mackstrap85, Mar 30, 2004.
  1. mackstrap85
    mackstrap85 Junior Member
    I have 95 civic hatch and made a swap from a D15 to a D16Y7. Which ECU should I use? I also wanna remain obd1.
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    You are going to want to run the 92-95DX ecu. and you are going to need a conversion harness: http://www.jkobdconversionharness.com/
    You do not want to run the 92-95CX ECu as it is 12 valve and the new motor is 16 valve.
  3. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
