y1 b16 tranny missing 2,4 and 5th gears after swap
Discussion in 'General Tech and Maintenance' started by blasterman87, Jul 11, 2009.
  1. blasterman87
    blasterman87 New Member
    what could cause a tranny to not go into 2/4/5th gears? it worked in an integra, was baught and bolted to the jdm b16 and swapped into a 92 hatch using haspro cable/hydro conversion, and 2/4/5 gears wont work, it just wont go into those gears... i thaught maybe the guy lied and that it was bad to start with but who would run a tranny untill 3 gears went out? and ive never seen 3 gears go out at once.. any input?
  2. Briansol
    i's probably the linkage or the conversion kit not being installed correctly.
  3. blasterman87
    thats what i thaught, im hooking up the linkage on it tomorrow in my ef so i hope thats all it was.. its a lsd tranny also
  4. awptickes
    MD
    Make sure you're using the correct linkage. It sounds like you're not.
    Can you get into all 6 gears while the engine is off?
  5. blasterman87
    i made a new thread, its doing the same thing in my car, and im using the right linkage, its a pos
