y7 vs y8
Discussion in 'Engine Building' started by sevenhillsbilly, Mar 31, 2008.
  1. sevenhillsbilly
    sevenhillsbilly New Member
    whats the difference between the two and which would be a better head to use?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the y8 is vtec
  3. sevenhillsbilly
    and the y7 is what just a normal head?
    which would be better head swap??
  4. AHHVTEC
    Alabama
    i mean if your wanting power the y8 is the way to go or the z6 head
  5. sevenhillsbilly
    ok so the y8 is the way to go for a head swap?
  6. sevenhillsbilly
    ok thanks for the advice and is there anything special that i would need besides a harness jumper
  7. AHHVTEC
    Alabama
    well since your putting it on a a6 block i think it would be easier to just put a z6 head on it,
  8. sevenhillsbilly
    so find a z6 head instead of a y8? and what is involved in the head swap there?
  9. sevenhillsbilly
    but what about cost? im kinda running on a tight budget and which would be better for the budget? but which is simplier swap?
  10. sevenhillsbilly
  11. AHHVTEC
    Alabama
    were not trying to be dicks or anything but this swap has been done millions of times sense 1998. so there should be 100% write ups just a click away
  12. sevenhillsbilly
    buddy club vtec conrollers any good?
  13. sevenhillsbilly
  14. 92civicb18b1
    92civicb18b1 The Trisexual
    It's just software, the actual burning of the chip doesn't cost much either, making a good map (tuning) is what costs money or you could learn how to use the program....but then again you have to know what you're doing or you're blow up your motor.
