y8 mani into ef hatchback help!
cardinalboy07
Mini swap a6 block with y8 head,mani,belt,p28
Now the dpfi to mpfi is done
Where do the hoses go from throttle body and EVAC go also from thetop of the manifold
Coolant routing for IACV - the nipple on the passenger side of the iacv goes to the back nipple under the TB. The front nipple under the throttle body goes to the coolant nipple on the the passenger side of the of the intake mani, where it bolts to the head.
One of the large vaccume ports goes to your pcv, i'd assume the lower one. The top larger one I'd assume goes to your brake booster if there isn't one on the back of the manifold for it.
