y8 oil pump
Discussion in 'Engine Building' started by je power, Feb 10, 2010.
  1. je power
    je power New Member
    my house
    Ive done some research and i cant find the answer. Can i use a z6 oil pump on a y8? I dont no how shim it but i can port. please help me out...o and what oil pan will i have to run?
  2. zach_teg_king
    zach_teg_king jdmzach "country boy"
    south central, KY (amishland lol)
    im pretty sure the y8 pump is different and pumps more oil than the z6 pump, therefore meaning you shouldnt use it..as for oil pans, you need a y8 oilpan, the z6 pan will fit but wont bolt up completely, one ot 2 holes wont line up right, meaning it wont seal right.
  3. je power
    je power New Member
    my house
    ok so shoul i have it shim or buy a high out put oil pump? i think it would be worth the money the oil pump i found was for like 205 so its not to much
  4. je power
    je power New Member
    my house
    its a toga high volume pump on horsepowerfreaks.com and its $209
