y8 vtec solenoid, which wires are which?
Discussion in 'Civic and del Sol - EG and EK' started by raceinspiredrex, Feb 9, 2009.
  1. raceinspiredrex
    raceinspiredrex New Member
    i have an 88 crx and know somebody's gonna say post in the ef forum, but the y8 head is from an ek, 97 ex to be exact. i'm not sure which wires are which on the vtec solenoid. i'm converting from obd0 to 1 and have a conversion harness. there's three wires from the harness and three on the solenoid, so that's all good. the wires from the harness say vtec solenoid signal, vtec pressure switch signal, and vtec pressure switch ground. i'm guessing that the vtec solenoid signal wire goes to the green/yellow wire that's by itself. i'm not sure about the other two that're together on the plug but i'm guessing that the red/white wire is the vtec pressure switch signal and the green/black wire is the ground. can anybody verify this? thanks guys i appreciate it
  2. raceinspiredrex
    bump. por favor. thanks fellers
  3. Riseagain97
    Riseagain97 New Member
    Normal,Illinois, United States
    hmmm on mine i have one green wire coming from that plug then there are 2 other wires connecting to the bottom of the solinoid.. but the color is similar.. I want to say the Green wire is the Signal wire and the red and black the pressure sender... let me get back to you on that they may be wired the different years I have a wireing diagram at home
  4. raceinspiredrex
    well the one that's by itself up top, that wire's green with a yellow stripe. the two wires on the plug, those two are green with a black stripe, and red with a white stripe. thanks a lot
  5. raceinspiredrex
    bump. please i need to know. thanks
    also, i completely disassembled my y8 head and am putting it back together now. i have the valve springs and cam in and try to put the rocker arm assembly on, but it won't sit flat, is that normal. there's nothing in the way or anything like that, but the whole unit won't sit flush, parts of it will but some won't. even if i tap it with a rubber mallet it still won't sit flat. do i just keep slowly tightening everything until it all sits flat? i'm afraid i'm going to break something because this is the first time i've done this on a honda. thanks guys
  6. serrilion
    serrilion In my own little world! VIP
    Vermont
  7. raceinspiredrex
    that's perfect! exactly what i was looking for! thanks a lot!
    can anybody answer my question about the the rocker arm assembly? if not i'll start a new thread since it seems everybody's overloooking this subject. thanks
  8. serrilion
    Vermont
    I get a hanyes Manual it will tell ya dude!
  9. raceinspiredrex
    i got a chiltons, but it isn't very helpful.
    i figured out the rocker assembly issue, it doesn't sit completely flat until you have everything tightened down. too bad my buddy's torque wrench isn't completely calibrated, resulting in me over-torquing the small outside bolts and snapping 3 of the 4. looks like i'm gonna hafta wait for some new bolts
  10. serrilion
    Vermont
    Thats a stinker, sorry to hear about that!
