Yamaha 350Twin Banshee?
Discussion in 'Other Vehicle Discussions' started by 94H_Ex, Jun 30, 2008.
  1. 94H_Ex
    94H_Ex Under employed
    Florida
    Alright I'm doing a side job for a friend of mine. He had bought a complete banshee that was in parts. well he's paying me to but the beast together. The engine on it has been to the shop. heres the list of whats "said" to be in it. so dont gun me down because someone else is retarded. shaved racing head, port and polished exhaust and intake, bigger jets, CF reeds, hot rod crank shaft. and 1mm bore.
    well this isnt all just about what the bike has. Ive worked on alot of atv's but this one is surely kicking me. and i m just asking this until tomorrow when i get a hold of the book for it and actually get all the info i need for the bike.
    its not getting spark. nor can i tell if its getting power anywhere else. i wont be getting the tool i need in order to pull the magneto off till tomorrow either. (clean it and make sure its doing what its suppose to do) I know that rust in or around your magneto can cause it all not to work right and do what it needs to do. and from what i was told its not the coil because the coil would of went out when theres power to it. not just sitting.
    as far as i know the bike was running before being disassembled. reason for disassembly was because the old frame was stolen and this bike came with a new frame. no one had the time or the tools to do the switch. except me.
    so any one who has some info on this problem of no spark.
    (if im not completely correct on everything thats in this post correct me then.)
  2. Celerity
    Celerity Well-Known Member
    Where did they get 1mm oversized throttle body butterflies ?
  3. 94H_Ex
    Florida
    no. 1 mm over sized pistons. im not really sure if thats even the correct bore that it has. but i do know before this bike was pulled apart. it was quick.
  4. efhondakid
    Akron-Canton, Ohio
    Is the magneto and pick-up rusted? If so knock the rust off with some sandpaper, then check spark again, Are the plugs fouled? The rev box plugged in? All the grounds hooked up?
  5. 94H_Ex
    Florida
    i dont know if the magneto has rust or not. the one tool, out of many tools i have, that i need i dont have. i need like. a pully puller. i have a flywheel puller.... but. no pully. revbox is connect. all the connections are connected.
    i could only find ONE ground on the entire harness. which was a ground near the Voltage ma bob (cant remember the name for it at the moment) towards the back. coil is connected right. sparks are brand new. i even ran a ground the the engine and on to the frame just in case that was needed. but still nothing.
    untill i can get that magneto off or get an extra coil to make sure that its not the coil either. i dont have a clue.
    but some one did offer my friend 3500 for the bike as sits. so tonight i m going to find out if he's going to do it. i just want to get it to fire so that way i can say. yeah. i finshed the job on that thing. and not be like. i dont have a fucking clue. want me to work on your car?? <_<
  6. efhondakid
    Akron-Canton, Ohio
    The key? I took the key out on my XR50 and at first I thought "Unplug the wires that go into the key and plug them back together" It doesnt work like that, if you unplug the key switch, leave all the wires unplugged.
  7. 94H_Ex
    Florida
    well the key is in it. but i know that on 2 strokes if you unplug the key they'll run. thats how most 2 strokes get stolen. all you have to do is unplug the key and kick start it. and go.
  8. efhondakid
    Akron-Canton, Ohio
    Right thats what I was saying. It may have been confusing how I tried to explain it though. You get it figured out yet?
  9. 94H_Ex
    Florida
    nah i didnt even bother to mess with it today. (yet another side job for gas money) I decided to give a day to think on it. and to try to find that damn puller >_< i might have to give in a buy one -_- hooray. spending more money. i hate being almost flat broke.
  10. TurboMirage
    autozone rents them. you get your money back when you return the tool.
