Yet another stupid noob ?
Discussion in 'HYBRID -> EG-EK / DC' started by cleanLS, Mar 3, 2007.
  1. cleanLS
    cleanLS New Member
    So i just found out the motor i got from the junk yard is a v-tec motor(D15Z1). So what computer do i need to work? Any v-tec computer will work right? Single and dual cam v-tec?Or just single cam v-tec? Shit i'm confuseing myself writing this. I'm an idiot.
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    Find a computer that is for your motor. It will be obd1. Any obd1 computer will work but they all have different fuel and ignition maps. So if you want your car to run good get the ecu that matches your engine.
  3. welfare
    welfare Ancient Member
    New York
    use a p28 ecu from a d16z6, d15b and d16z6 are close enough that it shouldn't matter, you are prolly gonna have to wire vtec tho.
    you can get the ecu from a 92-95 civic si or ex
  4. 801CRX
    801CRX Got Rice?
    UTAH
    Yeah P28.........would be the best bet.
  5. killercannible
    killercannible Senior Member
    I am assuming the d15z1 is the economy vtec engine. I have heard that they make good power on a p28 almost like a z6. But i hear that the cam profiles do not suit the ecu because they are made for low rpm fuel consumption.
  6. J-fabracing.com
    J-fabracing.com HS Vendor
    I think i got a ecu for that engine i will look if you want
  7. 92civichbd15b
    92civichbd15b New Member
    The exact ECU for that engine is a P07. I got a D15Z1 that I pulled from my EG if you need any parts in particular except for the head. (Just throwing it out there) :)
  8. Jokerluv
    Jokerluv Rockin da Z1 !!!!
    Princeton, Tx, USA
    p28 will throw a CEL unles you swap a z6 dizzy
