Yo
Discussion in 'Members' Lounge' started by brian11to1, Dec 1, 2003.
  1. brian11to1
    brian11to1 Senior Member
    I was on aim and talking to someone from Honda-tech... he says he has 2 JDM YS1 transmissions, one with LSD one without. I was under the impression YS1's were not JDM units. Is this true they were/are JDM?
    The convo:
    Theoneinthe760Ca: i have like 4 jdm cables
    Integra1990Racer: wanna trade?
    Integra1990Racer: you pay shippin on tranny
    Integra1990Racer: i pay shippin on engine
    Theoneinthe760Ca: well
    Integra1990Racer: or motor
    Theoneinthe760Ca: see i have a j1 s1 and 2 ys1's
    Theoneinthe760Ca: i need 3 and i have 4
    Integra1990Racer: ys1 isnt JDM
    Integra1990Racer: 90-93 Integra's came with it
    Theoneinthe760Ca: nope
    Integra1990Racer: USDM integra's came stock with YS1's
    Theoneinthe760Ca: the YS1 was also a JDM tranny
    Integra1990Racer: really?
    Theoneinthe760Ca: i have one with stock LSD and one with out
    Theoneinthe760Ca: both are JDM
    Theoneinthe760Ca: the 90-93 integ ys1 has a bigger shaft a hyrdo one
    Integra1990Racer: mmm didnt know that..... goin by the reference section on hondaswap.com it says ys1's were not JDM, USDM only
    Theoneinthe760Ca: its diff then the regular JDM bseies
    Integra1990Racer: 90-93 integras are cable trans.
    Theoneinthe760Ca: skip hondaswap some of they chet is wrong
    Integra1990Racer: Ill get it figured out
    Theoneinthe760Ca: i know but the diff between JDM and USDM is the shaft spline, the USDM has a hydro size one when the JDM has a smaller one like the rest of the jdm cables.
    This true?
  2. brian11to1
    Bump, someone confirm this.
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    im not 100% positive, but im pretty sure the ys1 is a usdm-only.
    but that's just me. saying that because i've never seen a ys1 on a jdm motor.
  4. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    YS1 is both JDM and USDM... It's the 92-93 teggy tranny.
    In 90-91 There is the same problem.. .The "S1" is US and JDM, the US having long gears, where the sought after JDM S-1 is very short gears.
  5. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Did the YS1 come with multiple gear pacakages? Because the YS1 that came on the 92-93 LS sucks, I didn't know that JDM land called the XSi tranny a YS1 as well. I always thought they got the Y1 or the S1.
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Ok check it out, the YS1 was indeed from Japan and the US, BUT, in the US it came on the RS/LS/GS/and SE and the gear ratio was...
    1st 3.230
    2nd 1.900
    3rd 1.269
    4th 0.966
    5th 0.742
    FD 4.266
    In Japan it came on the XSi/RSi and had this gearing...
    1st 3.307
    2nd 2.105
    3rd 1.459
    4th 1.107
    5th 0.875
    FD 4.400
  7. lsvtec
    Thanks for the info.
    What tranny came on the 92-93 GSR? Was that also a YS1?
  8. xj0hnx
    C.C.TX.
    Yes, but it had a different 5th...0.880
  9. lsvtec
    I was under the impression that the final drive was different for the GSR as well.
  10. brian11to1
    awesoem thanks guys, so this guy is legit. Thanks again everyone
