Yonaka Coilovers & Racing Radiators
TorontoJdm
BRAND NEW YONAKA COILOVERS:
92-2000 EG+EK CIVIC *********$650.00+shipping*********
93-97 CIVIC DEL SOL *********$650.00+shipping*********
94-01 INTEGRA DC2 *********$650.00+shipping*********
02-06 RSX DC5 *********$850.00+shipping*********
NOW AVAILABLE!
Yonaka Motorsports street coilovers.
Ideal for street cars and weekend racers.
Featuring:
All Aluminum Upper Mounts
0-4" Height adjustment.
Fully Threaded Mono Tube Shock Absorber.
Inner bump stop to prevent damage cause by rapid compression impacts.
Wide range of height adjustment without changing the spring compression.
Bottom of the shock is threaded to allow height adjustments without having to shorten the suspension travel.
Rubber dust shield protecting piston for long life.
Adjustment tools included.
Spring rates are as follows:
Front springs: 12kg / 180mm
Rear springs: 6kg / 200mm
Warranty :
1 Year
BRAND NEW YONAKA ALUMINUM RADIATOR FOR 92-2000 CIVIC
With built in aluminum Fan
*********$300.00 shipped*********
This is a 100% aluminum radiator with aluminum end tanks. This is a bolt-in fit, works with OEM fans. It is designed to replace the OEM radiator of Honda Civics with manual transmissions only.
Dimensions:
- Total Size: 15.25" long x 18.5" high x 2" thick
- Diameter on inlet/outlet is 1"
Performance:
Flows 200% more coolant than the stock Honda OEM 5/8" thick radiator.
Application:
Designed for use in any 1992 to 2000 Honda Civic (except 99-00 Honda Civic SI)
Warranty :
Lifetime warranty
DC2 RACING RAD + SLIM FAN $350.00+SHIPPING
Performance:
- Flows 200% more coolant than the stock 5/8" thick radiator
- Works with either JDM or USDM engines.
- Comes with aluminum fan shroud kit
- Direct OEM fit
Dimensions:
Overall dimensions: 26.4" x 18.3" x 2.15"
Core Size: 13.78" x 25.9"
Inlet: 1.25"
Outlet: 1.25"
Core Thickness: 2"
Core is fully polished to a mirror finish
- Comes with aluminum fan shroud kit which includes:
Aluminum Shroud with two 12" Performance Electric Fans
Overall Size:
Height - 17"
Length - 25.7"
Width - 3.5" (including fans)
This fan shroud serves a very important purpose in securing the fan blades in place which otherwise could potentially damage other essential components in your engine.
Warranty:
All rads come with a 1 year warranty against any manufacturing defects.
ALSO AVAILABLE ALUMINUM RADIATOR FOR 1990-1993 INTEGRA, 94+ INTEGRA DC2 AND RSX DC5, please PM me
PLEASE CONTACT US FOR MORE INFORMATION
