Capt. Orygun
Win the Day
Granted I can't pull my AC so long as I live in TX, but every little bit helps.
Originally posted by lsvtec+May 13 2003, 10:09 PM-->Silverchild79@May 13 2003, 08:02 PM
Wuss
I live in Southern New Mexico. It was 98 degrees here today. I don't have any AC and it is fine.
Originally posted by liquid00meth@May 13 2003, 10:08 PM
if you keep it, your a pussy.
Originally posted by pissedoffsol@May 13 2003, 11:32 PM
"removing" the power steering is a little more involved than you think.
two choices-
A- swap the entire rack- a piece that isn't exactly easy to get at, and isn't fun from what i hear.
B- remove the pump, and loop the fluid line so that the rack stays lubed.
B saves you 15 lbs tops.
A saves you about 20-25.
is it really worth it?
Originally posted by Calesta@May 14 2003, 08:36 AM
Keep the AC. It's a must in Texas. I'm going to hate the CRX when it gets even hotter...
Eric- there's a HUGE difference between the dry heat in New Mexico and the super wet nasty humid heat in Texas that doesn't even let you sweat at 80 degrees.
