z6 harness on bseries?
laostha
I have a 92 ls sittin in my yard and wanted to know if i could use the single cam harness on it. I have the ls harness but the plugs at the end are different. there are 2 of them on the ls and i have 3 plugs.
if both engines are obd1 then its plug and play the 92 ls is obd1 but what are you putting it into.
its going into an eg. another thing i just remembered is that these motors have like a seprate map sensor the mounts to the firwall instead of the throttle body. theres a green plug on the back of the block next to the oil pressure sensor im not sure what it is.
