z6 runs like crap at idle
Discussion in 'General Tech and Maintenance' started by where eagles dare, Jul 11, 2003.
  1. where eagles dare
    where eagles dare Member
    when i'm crusing down the street in neutral it idles correct (800-900)
    when stoped at a light it idles very low (200-400)
    when i press and release the brakes very hard it idles up for a second, then back down to (200-400) (it idles up after i let off the brake)
    when i turn the air on it idles somewhere in the middle (600-700)
    when i tap the gas quickly while idling: it almost stalls sometimes, but if i get on it slow in revs up just fine
    my best guesses for cause of problem:
    fuel problem: filter/injectors
    vaccum leak: ???
    any suggestions?
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    no vac leak would cause it to idle really high...
    did you adjust the idle screw?
    did you try the IACV test??
    did you read my article? there is alot more to this site then just forums
