z6 sounding rough
Discussion in 'HYBRID -> ED-EF / DA' started by c-rex-beat, Mar 15, 2009.
  1. c-rex-beat
    c-rex-beat yeah, it's a vtec.
    tyler, TX
    I just swapped in a z6 into a 89 crx. I have no cel but idles a bit rough and sputters when given accelerate. The cel works. I noticed I have one plug and two places to put it. (sounds like this past weekend) anyways, it has a green and red wire both with white stripe. does it plug on side of head or at thermo housing? any help would be great.
  2. RoboRex2005
    RoboRex2005 New Member
    Cleveland, Ohio
    Is is located in the distributer harness? Did you do a dual point to multipoint swap?
  3. c-rex-beat
    tyler, TX
    no it is a si multi point. The dizzy harness worked fine with the mini me swap.
  4. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    pics?
    decent ones will help identify whats unplugged.
  5. c-rex-beat
    tyler, TX
    found the problem. Bad o ring on map sensor. lol. anyways Thank you for all you guys suggestions.
