z6 swap in a 91dx questions
Discussion in 'HYBRID -> ED-EF / DA' started by tuptup, Jun 10, 2009.
  1. tuptup
    tuptup New Member
    south dakota
    Im going to swap a d16z6 with my current d15b2, The b2 has really bad compression so im not doing just a minime swap.currently i have a complete d16z6 with the wireing harness(no wires cut), altnator and headder. I would like to know what ecu and obd i will need to complete this swap. i would also like to know what the plug and play kit is to make my cars harness match up to the new computers. Is that all i will need to do the swap?
    -Tup
  2. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    You need a P28 ECU (OBD1). As well, you need an OBD0-OBD1 conversion harness.
  3. GlassHeadlights
    Calgary, AB
    Rywire.com sells a whole plug and play wiring kit for your application. You still need a P28 ECU after that though.
    Rywire - Online Store
  4. YNOT
    YNOT New Member
    san jose ca
    how about the motor mounts do does change
  5. d-mon
    d-mon what r u compensating 4?
    use the motor mounts from the from the b2. (driver side = angled)
