z6 swap into dx
tylerk2311
ok here is the deal i need help i put a D16Z6 into a 1994 civic dx 30,000 miles on the motor it has a very bad problem with blow by enough to blow oil out of the oil cap when it is off i have done a compression test on each cylinder there is about 130lbs each ok the last problem it runs awesome but when you gas on it it smokes a little bit and smells like gas please help
