z6 swap questions
Discussion in 'Civic and CRX - EF' started by 8ballsin, Sep 20, 2008.
  1. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    i bought a z6 and it didnt come with intake or harness is it possible to us my intake manifold and wiring harness off my D16A6. I know i would have to wire in vtec and wire in the connector at the ecu to run a p28. What do you think? This is all going in my 90 crx and it is going to be running at 12psi of boost
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yep you can rn your intake mani..and yea you can run your harness,but you will need to run a dizzy adaptor and an obd0 alt.
  3. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    why would i have to change the alt. my harness plugs right into it
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    if it plugs right in then go for it..i was under the impression that obd0 and obd1 alt were differant
  5. austinav10
    austinav10 New Member
    Hey guys I am new to this site, I have a z6 in my ef running my a6 harness and p28 ecu with jumper to the ecu and dizzy. So with the ecu jumper harness it comes with four adpt. and a orange and blue wire. I know were the three of them hook up too(4 wire sensor, vetech solenoid, oil control) but I still have one adapter hanging around. About the 4 wire o2 sensor, do I just cut off my old one wire o2 sensor and replace it with the 4 wire and hide the one wire o2 sensor?
