z6 y8 arp head studs differents
Discussion in 'Civic and del Sol - EG and EK' started by crxpower24, Feb 27, 2013.
  1. crxpower24
    crxpower24 Member
    So im about to do a mini me on my civic n i wana get head studs for it i found some y8 for 94$$ is there a difference between da z6 n da y8 or wich one's should i get can somebody help me.
    Ps da block is a b7 n da head is a z6
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    not sure maybe go to the home site and see if the part numbers are the same.
  3. crxpower24
    crxpower24 Member
    Der not da same number witch 1s should i use then
  4. E_SolSi
    use the ARP z6 head stud kit
    the OEM part number fot the head studs are the same for the b7 and the z6 (90005-PM3-003)
