zc and z6 sohc vtec
Discussion in 'Engine Building' started by 1994ex, Jun 21, 2005.
  1. 1994ex
    1994ex Member
    what is the difference between these two motors? I know that one is from japan and the other one is from the US. Besides horsepower, what is the main difference? Can I use the zc ecu on the z6? any help would be greatly appreciated.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Depends on which ZC ECU it is.
  3. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    if you want a mechanical break down with spec. i will post a few for you on the differences ok
    ------------d16z6-------------------------------------sohc zc-------
    piston to
    deck height 0.000 in----------------------------------0.040 in
    Piston Dome
    Displacement -10.10cc-----------------------------------3.40cc
    (cc per piston)
    Combustion
    Chamber 34.60cc-----------------------------------43.80cc
    Volume
    (cc per cylinder)
    head gasket D16Y8 - D16Z6---------------------------D15B7 - D16A6
    Thickness 0.03700000 in----------------------------0.04800000 in
    compression 9.139 :1cr---------------------------------7.966 :1cr
    ratio
    i have a sohc zc that has pm6 pistons in it and that what i used for the specs. i heard that sohc zc do not come with dome top pistons so i am lost for what they come with stock
    but here is the site i got the info from http://www.knology.net/~jediklc/D.htm
    i hope this can help you
  4. 1994ex
    1994ex Member
    i have the p70
  5. sohcslammer
    sohcslammer Senior Member
    Bay Area
    Ummmm.... I'm pretty sure the sohc ZC is the same as the d16z6. Exactly.
  6. Dark91zc
    Corona,CA
    sohc zc and d16a6 are the same
  7. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    That's a bad ass site, is there one like it for the B-series and H-series?
  8. phunky.buddha
    Dallas / Fort Worth, TX
    The cam is different.
  9. ryan89crx
    ryan89crx Senior Member
    Washington State
    yep, zc is SLIGHTLY more agressive
  10. phunky.buddha
    Yup. Enough to make a difference though. I had mine measured.
  11. sohcslammer
    Bay Area
    Don't you guys mean D16Z6?
    As far as I know, the A6 is non vtec and the sohc ZC does have VTEC. It's the dohc ZC that is non VTEC.
    d16a6 = sohc non vtec 108hp
    d16z6 = sohc vtec 125hp
    sohc zc = sohc vtec 130hp
    dohc zc = dohc non vtec ?hp (I think it's 130 as well?)
  12. Punisher
    Punisher Member
    I've seen both ZCs, non-VTEC and VTEC.
    The SOHC ZC VTEC and D16Z6 are basically the same motors but with different camshafts. External appearance between them are the same. However, on the SOHC ZC VTEC, you will see ZC stamped on the block. There is also another JDM variant, the D16A, which resembles the D16Z6, but the block is stamped D16A.
    The SOHC ZC and D16A6 are also basically the same motors but with different camshafts again. External appearance between them are the same. However, on the SOHC ZC, you will also see ZC stamped on the block. The SOHC ZC motor should give out 114-115hp.
  13. ryan89crx
    Washington State
    external AND internals are exactly the same between the a6 and sohc non vtec zc, rods, pistons, cylinder head, everything. the only difference is in the cam. and of course the stamp on the block
  14. phunky.buddha
    :werd:
    I've owned the SOHC non-VTEC ZC. If you look at the threads on dseries.org where a few guys from a shop measured the SOHC ZC camshaft, they got the measurements from MY SOHC ZC engine.
  15. sohcslammer
    Bay Area
    Cal, you are confusing me bro..... I thought there were only 2 ZC motors. A dohc and a sohc. In my experience the sohc has VTEC while the dohc does not. Both should be @ 130 hp. Neither, I thought were sohc non vtec with under 120 hp. My friend had a VTEC sohc ZC motor in his 94 coupe. It felt exactly like my d16z6 and sounded like it too. What gives? Is the d16a6 really VTEC, or dohc? Are there 3 ZC motors? I'm so confused.... :blink:
  16. 1994ex
    1994ex Member
    if the only difference is the cams, can i use the zc sohc ecu on the z6. will it run like shit or will it run normal. am i going to have to change out the cams.
  17. Dark91zc
    Corona,CA
    if you have the zc vtec ecu go for it otherwise get a get a p28 from a sol for the z6
