i have a 89 crx with the sohc zc swap and the si trans. the clutch that is in it cannot handle the new found horse power need help with an upgrade clutch any parts numbers of refernce would be great
just get an upgraded clutch for a d16 its all the same. I also have a sohc zc and i got an act for around 200 and some change. but i got a question for you? how does the zc run with the si trans? i got my dx trans bolted to it and its about to go. the main bearings in the trans are wineing like hell and you have to keep the motor in high rpms to get any thing outta it. but its a great lil motor for 400 bucks.........
The car is really pretty fast pulls hard all teh way throught the rpm except when you shift hard the clutch will slip. dam noem replacment with only a thousand miles on it
