Zc + D16z6?
Discussion in 'HYBRID -> EG-EK / DC' started by shermsol, Jan 21, 2003.
  1. shermsol
    shermsol Junior Member
    does anyone know if a d16z6 engine will bolt up to a ZC tranny?
  2. 88civicHBz6
    88civicHBz6 Senior Member
    as far as i know it won't try a SI tranny or something like that. and what car is ti going into?
  3. Jeef
    Jeef NO MA'AM Moderator VIP
    If a zc motor can bolt to a crx si tranny with no problems, and a z6 motor can bolt to a crx si tranny then why wouldn't this work.
  4. sohc em
    sohc em Member
    Charlotte, NC
    are you referring to the ZC SOHC VTEC or the ZC DOHC non-vtec, well either way they will both work, but heres the catch if your car is a civic from the year 92up you have a hydraulic tranny and the 91and lower civics use a cable shifted transmission. You can but i wouldn't advise due to the extra work to put a cable tranny in a hydro car and vise versa. The ZC sohc vtec is hydro and the Zc dohc is cable, but i am going to guess the zc you are referring to is the dohc version. but tell me the car and situation you are proposing and i can give you more info.
  5. shermsol
    its going into a 89 CRX si and yes I am referring to the DOHC non VTEC one.
  6. 88civicHBz6
    i would like to know if the dohc will bolt up also, and sorry for the wrong info man. and are the gear ratio's better than a 88 to 91 si civic trany? thanks? :D :D
  7. sohc em
    sohc em Member
    Charlotte, NC
    yes it will most if not all d series trannies are interchangeable
  8. NIMO
    NIMO Member
    Don't forget to change axles, the ZC-DOHC requires Integra axles, they have a half shaft, and the CRX don't, good luck.
  9. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Aren't the zc's also D series and if so doesn't that mean,they also use one piece axles? :huh: Just nod up and down.
  10. rex2nr
    rex2nr Junior Member
    not to hijack, but which engine would you recommend using of these two?
