zc distribuator
jessef
i have a dohc zc in my 90 hatch si and i got the stock distribuator on it and its held on by a washer and bolt. I was told i could put a 89 integ distribuator and it would work better. is this true?
just rewire the zc dist. you have to use the plugs off the zc harness and extentend the cylinder position wires to the sensor on the exhaust cam. also the teg dist is the same as the zc so you would have to modify it the same way.
