ZC Distributor Issues
whitezc
i just installed a sohc zc. i did not come with a distributor so i used the stock SI one. my engine is cranking but no spark to the plugs. my coil is getting juice..just nothing comming out of the distributor.any help would be appreciated
is the crank sensor hooked up right mine did the same thing and the crank sensor was not hooked up correctly
