ZC DOHC 2 nd generation
eastcoastcivic
hi guys , :)
i have a civic eg with a zc DOHC 2 nd generation swap.
i'm looking to add more power or some pep to my engine.
since you all probably know , it's pretty hard to get parts for
that engine.
any suggestions???
thanks
for the head theirs not to much past porting and pollishing valve job and resurfacing the deck. unless u send the head some place to have the spring purch modified to take b series sprins and cams.
the bottom end u canuse most any d series mod. pulleys pistons stroker kits.
or look for parts for a 86 to 89 integra the motors are alost the same.9difrent compression and engine mounts0
Wow... B series cams in a D series block? They won't fit- different length, different bore center spacing- you'll have some lobes running in the cam journals instead of hitting your valves.
I would go for custom forged pistons and upgraded cams (there are some out there) to get all motor power, maybe just bolt up a turbo for some more power if you don't want to go inside the engine.
