D Drenni Senior Member Feb 9, 2004 #1 What cam gears should I use on a ZC DOHC, or should I refase from what car should I order them, if i was to order them from AEM. Thanks guys
E_SolSi Member of the 20 nut club Moderator VIP Feb 9, 2004 #2 D16A6 (first gen integra) dont get AEM ... they suck... they are known to slip get some with at least 4 bolts and ones that can not be adjusted more than 5 degrees
D Drenni Senior Member Feb 9, 2004 #3 Wait can they be found, or which other brand are you reffering to, maybe skunk or which other. Someone said b16 cams , Is that true, thanks
