Zc has different mounting
Yspeed
Member
I have a 89 civic Si, And I just bout the Zc but the Zc mounting is on the side,Allmost nere the headers. How do I get it to mount up? And there are also 4 hoses coming out of the distributer what is that and what do I do about it?Thanx
sounds like you have a brown valve cover ZC for the 1st gen CRX with vacuum advance distributor - you need black valve cover ZC - the 1st gen ZC does not have ZC stamped in square flat area on front of block by the transmission - it is on top of block above the starter in rectangular flat area next to transmission
