Jdubspeeds
I got a crx at my shop right now. Its a dx to zc. It runs but when you give it gas it bogs it self out, and clouds. I checked the compression its 180 across the board. Im getting spark and fuel delivery appears fine. Its pointing me toward a timing issue. Couple questions though.
1) When the 2 cams are pointing in the up position. Does the mark have to be right on or is ok to say have the intake cam a half tooth off? (this is how it is currently set)
2) This guy bought a brand new distributor for his zc but the one he bought was for 91 crx si. I am 99 percent sure that the firing order on the zc is the same as most hondas. (and pics of your zc motors would be appreaciated.)
3) Its not throwing any check codes, the ecu appears to be working correctly.
Thats about where im at right now, any advise would be appreciated I should know what the problem is but im just not figuring it our for some reason.
Its DOHC zc btw
Its DOHC zc btw
