ZC in 91 CRX DX
Discussion in 'HYBRID -> ED-EF / DA' started by HerpsMcDirt, Jan 29, 2009.
  1. HerpsMcDirt
    HerpsMcDirt New Member
    TEXAS
    I was about to purchase a b16 to swap into my 91 dx, when the turd sold it out from under me. so now I've decided that my only option is to go with a ZC. I have been looking around and have seen the sohc and the dohc. Does anybody have a preference towards either of these?
  2. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    dohc is a Lot better than sohc. 130ish hp on the dohc
  3. HerpsMcDirt
    TEXAS
    what's the wiring going to take? It's going in a DX so is it going to need modification to read the MPFI?
  4. OGMatt
    vic B.C. Japanada
    In order to convert your dual point injection DX to multi-point injection you will need 4 injector plugs, an injector resistor box, extra wire, a wire stripper/cutter, heatshrink and/or electrical tape, and some patience. Also, when doing this conversion I would highly recommend soldering all connections and heatshrinking them. If you do not have access to heatshrink neatly wrapped electrical tape will do just fine. It is also extremely helpful to have an extra multi-point injection engine harness laying around to take plugs from (i.e. injector plugs, injector resistor box plug, and distributor plug). Listed below is a straightforward and easy to follow set of instructions to help you complete your DX to ZC swap:
    DX to ZC
    Inside car @ ECU
    · Pins B10 and B12 are empty. Unused pins can be taken from B2 or B11. Some models have a wire located at B12.
    · Cut orange and white wires off at C1 and C2 and connect them to wires added at B10 and B12. Orange-B10. White-B12. Leave enough wire for next step.
    · Run wires from C1 and C2 (direct ECU connection) into the engine compartment. Label these wires for later use.
    · Cut wires at A3 and A7 leaving plenty of wire. Run these wires into the engine compartment and label them for later use.
    Outside car
    · Transfer DX wiring harness over to ZC engine.
    · TPS and EACV plugs are too short and must be extended.
    · Be sure to switch green/white and yellow/white wires on TPS
    Injectors and injector resistor box
    · Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box.
    · Connect the yellow wire from the DX injector to the #1 injector (brown wire).
    · Connect the red wire from the DX injector and run it to the #3 injector (blue wire).
    · Connect the A3 wire to the #2 injector (red wire).
    · Connect the A7 wire to the #4 injector (yellow wire).
    · Connect the 4 red/black wires from injector resistor box to each injector.
    Cylinder position sensor
    · Connect C1 to blue/green wire on cylinder position sensor plug. · Connect C2 to blue/yellow wire on cylinder position sensor plug. Thats it. Double check everything and start it up. Good luck HerpsMcDirt!:)
    1 person likes this.
  5. George777
    George777 ^^ Likes Bewbies
    With your mom
    If you were planning for the B16, why not just do a B18A/B swap instead? It's going to all the same stuff for the install minus the vtec wiring.
  6. HerpsMcDirt
    TEXAS
    Money is what's stopping something bigger. I was getting a b16 w/ tranny and some other goodies for $800. now I have to do something quick and cheaper(er).
