Zc Into 5th Gen?
Discussion in 'HYBRID -> EG-EK / DC' started by willevans, May 28, 2003.
  1. willevans
    willevans Junior Member
    Can you drop a zc into a hatch w/o new engine mounts?
    What obd is the zc and do i need a wiring harness for it?
    thanks.
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    it would fit if you used all of your 5th gen d-series mounts. however, the motor is obd0 and you will have alot of wiring to do and that swap is not reccomended.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Not nescessarily,Honda was still using ZC's in some of the 6th gen's,so it depends on which one you're getting.
