ZC into 88 crx help !
Discussion in 'Civic and CRX - EW' started by nowtrime, Aug 8, 2006.
  1. nowtrime
    nowtrime Junior Member
    well as it says i need help. i just swaped a DOHC ZC fom an 89 integra into my 88 crx HF i need wiring help i dont know what i need to change over. im using the stock 89 integra ECU but i dont have any spark or injector pulse can anyone help me out with this ? what pins do i need to move around and where do i move them ? [​IMG]
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    is it a DOHC ZC or is it the Integra D16A1? - the A1 is not a ZC - the only wiring you need to change is at the distributor - go here:
    http://www.zcspeed.com/HFZCwiring.pdf
  3. nowtrime
    its a DOHC out of an 89 integra and im using the integra engine harness i dont have the hx harness
  4. jlicrx
    Colorado Springs
    it will not run with the Integra engine harness - you need to use the HF harness - all of the wires in the Integra engine harness connectors that plug into the chassis harness at both the driver's side and passenger side are in different locations from the wires in the HF chassis harness
  5. nowtrime
    thank you very much for your help ! :)
  6. Mr.Gerbil
    Mr.Gerbil Check your six
    how the hell did you get an A1 to bolt into an EF without some extensive customization?
  7. 5speed4life
    5speed4life Senior Member
    Cleveland Ohio.
    I am curious as well.
  8. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
