ZC into 94 4door with d15b7
93f22a1
is this the same as swapping the OBD0 DOHC ZC into the crx? only changing the 2 wires at the distributor or is it more elaborate than that? i have the ZC NOT A B18 or B16. i have searched every page having to do with swaps and couldnt find anything about the ZC swap for the 92+ civic. any help would be appreciated.
use your single cam distributor, all wiring will be the same. use your newer harness and alternator to save. i dont remember if your headers will match up...
only a dohc zc dizzy will bolt up. just get the 0bd1 ecu and dizzy since the d15b7 is 0bd1.
the ecu is a p29, and the dizzy is a TD43U
this is a dual cam D series motor, not a b series. the single cam NON vtec ditributor is the only one that will work.
are you quoting what i said??
the only way a sohc dizzy will bolt up is if you hack the shit out of it. i said only a zc dizzy will BOLT UP.
