I ordered a ZC from hmotors and it is currently en route. I had a few questions I wanted to verify before it got here in case there are any last minute parts I may need to grab before installation because I will be using the ZC transmission as well.
Im not sure if axles are coming with the motor, the intermediate shaft is. What axles will I need to use? Ive seen 90-91 teg axles mentioned.
Will there be any modification needed, ive seen mention that a few rings need to be removed in order to make fitment?
Im installing into a 91 HF and I have seen mention that I will need Si hubs instead. is this true?
Thanks in advance for answering what could take me hours in search to find....
