ZC motor with spun rod bearing?
crombie09
Member
I found one of these locally, for $100. The guy said its complete except for some sensors and the dizzy. Is it worth $100? -crombie09
is it the DOHC or SOHC? and im thinking thats a pretty good deal, ive heard of them running ~500 for a DOHC
Its a ZC DOHC I thought that was the only way they came. Maybe your thinking about the d16z6? That is a sohc vtec motor. Anyway I got the complete engine, in. and ex. manifolds, pcm with a ZC chip and 2 other chips that are programmed. The only thing wrong with the engine is the spun rod bearing and I need to get a dizzy. -crombie
Where do I find rod bearings for this thing? I also need main bearing and a gasket kit. -Thanks-
Edit: ok I found all the gaskets now what about the bearings?
