Zc Or B18a1 Swap For A 88crx Dx?
Discussion in 'HYBRID -> ED-EF / DA' started by erebunicrx, Jun 13, 2003.
  1. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    I want to do a swap for my 88 crx dx. but dont know what motor i schould do. i know the motors and tranny will cost me about the same all i will rebuild both motors before i put them in. i know i can just drop the zc in with some wire mods but wich motor is better?
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    the b18a will have more aftermarket support, more torque/hp, and take a little bit more work to get in, and cost a little bit more, but in the end will be a much better platform for you to have... you could turn it into an ls/vtec or turbo it. IMO there are more options with b18.
  3. civiceg6
    civiceg6 Member
    Yeah what he said .. B-series is the way to go. There also a motor from the 1986-1989 Integra. Same as a ZC. Might be cheaper too since those cars go for pretty cheap. Also you got all the stuff you need from it.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    Nope, sorry.. correcting you again. The 86-89 Integra engine makes less power than the DOHC ZC because of a different head (118-ish vs 130-ish), and has different mounts as well. It takes a little more work to bolt in a D16A1/A8/A9 than it does a ZC into a USDM CRX.
