zc or d16*?
Discussion in 'HYBRID -> ED-EF / DA' started by sunshineacid, May 22, 2006.
  1. sunshineacid
    sunshineacid Junior Member
    So I have a two pronged question:
    my civic (88 dx 3door) is slowly going out. 220k miles, its about time for an overhaul =P
    im trying to decide what engine to put in my car.
    what i want: a little more power (120-130ish will be fine)
    good on gas
    *EASY INSTAL*
    i just finished my swap from a ka24e to de and no matter what people say, the wiring on that swap was a nightmare. so im very interested in a genuine easy swap
    so this puts me into the 92-96 vtec d16 or zc realm.
    which one do you guys suggest based on my requirement?
    which has better gas mileage?
    im not interested in beefing either of these up in the future. stock use is fine (otherwise i would have opted for a b engine =P)
    also
    im planning on switching to a crx si guage cluster because it has a built in tach. ( i *hate* standalone tachs)
    will this be compatable with both of these engines?
    thanks in advance =)
  2. sunshineacid
    so you think that the DOHC zc would be a better for this?
    IIRC the dohc runs 9.6 compression. i usually run 9.1 on 87 octane. will that require 89?
    http://www.hmotorsonline.com/shop/sc2000se...page&item=30020
    is that the engine youre suggesting?
    i often wondered the wiring difference between the DOHC zc and the SOHC, but i wasnt able to find much.
    also, would the crx si guage cluster be able to hook up to this unit?
    i would really love to use the tach, but not have an huge tach sticking out on my dash =P
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Yea gauge cluster will work but if you're doing OBDI you'll need a cluster that reads a digital VSS(for the speedometer). The SOHC ZC is pretty much a D16A6 out of the 88-91 Si's. 9.6 should be fine with 87.
  4. sunshineacid
    sorry for the 20 questions, but you guys know what youre talking about, so i figure ill press my luck =P
    if i get that engine, do most parts cross over as american parts, or say if i need a new distro or alt, will i need to source from japan?
    i know this is kind of a strange question, but i used to be a nissan guy w/ a japan built ca18det. 99% of the engine parts were used on the pulsars here, so thats where my question stems from.
  5. 90SiZC
    90SiZC Junior Member
    In it's way the ZC is more like an 1G Integra engine. I'm running an Integra distributor on my '89 ZC (1990 Civic Si US model) and the Integra brain. The ZC has one of the sensors on the camshaft that normally lived in the Civic distributor (TDC??? brain fade sets in).
    When my swap was done the shop doing the install reused the Civic distributor connector since I was reusing my Si harness. Huge mistake. It's not hard to pull the wires and use the Integra type connector on the Civic harness.
    I have my own questions on which temp sensor the ZC uses... the Civic type or the Integra type. Or is it unique?
    Cheers,
    JimG
  6. 91civichbstd
    91civichbstd Junior Member
    Detroit, MI
  7. K2e2vin
    Raleigh, NC
    Doesn't the ECU use speed as a reference for some stuff like VTEC actuation though? I'm using a electric VSS so that I can use FTL/FTS with Crome :) .
  8. sunshineacid
    awesome awesome.
    thanks so much guys.
    is that a fair price for the long block and the ecu?
    ill need to source an si tranny as well
