brian11to1
I was told this is a D16A8... is this correct?
Is it?
Is it?
Quoted post[/post]]
id say yes, it is a d16a8
Quoted post[/post]]
easy way to tell is the a8 had the ridges...the zc looks like the y8
Quoted post[/post]]
shouldn't the block stamping say D16A8 or D16A9?
i have never seen one but they are rare and put out serious HP figures...
Quoted post[/post]]
Ive read somewhere more like 142hp, but who knows if that's accurate?
Quoted post[/post]]
Thats the D16A8, I can tell from the valve cover.
this is from Civic4g.com. just to make sure i dont give you any false info.
"Next in line was the 1.6L SOHC. Simply 1.6i for the European market and Si for the American market (US top model). (not to be confused with the JDM Si which is a 1.6L DOHC)
Second highest model was the JDM Si. It was equipped with a 1.6L DOHC (ZC) engine and delivered 130hp. The EDM 1.6i GT and 1.6i-16 (depends on country) had a ZC like 1.6L DOHC engine and had a stock 124hp (D16Z5) or 130hp (D16A9). All DOHC engines are equipped with Honda's multipoint fuel injection system (although there seems to have been a 1.6L DOHC non-VTEC with dual carburetors for the 4th gen.).
HP cant be any more than 135, the d16a8 is basically a D16A1 with different mounts.
D16A8/9 1595 137@6800 108@5700 9.5:1 75 90 dohc no 0 1988-1989 Integra
Quoted post[/post]]
actually, the D16A8 with the ridged valve cover was from the UK Rover - the Honda Civic/CRX had valve cover same as JDM DOHC ZC - here are a couple of pages from the Haynes Rover 216 & 416 Manual - note the horsepower for the A8 - the same engine was in 88-90 Civic/CRX in UK
Quoted post[/post]]
Quoted post[/post]]
thanks man, but we've already established the engine is from a 88-89 Integra.
