ZC or D16Z6 for 89 CRX SI?
Discussion in 'HYBRID -> ED-EF / DA' started by tdaddylove, Mar 22, 2004.
  1. tdaddylove
    tdaddylove Junior Member
    I have a ZC already in my car and the hp is rated at 130. I can get my hands on a D16z6 SOHC vtec engine with tranny and all, but i'm not positive its worth taking out my ZC. The D16z6 is rated at 125hp but its vtec.
    Also, is there a way to keep you obd0 stuff instead of converting the harness to obd1?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    If you already have the ZC and it's running fine, keep it. If you want to swap to the D16Z6, you can still stay OBD0- just run to something other than the ECU to control the VTEC, like a VAFC. That's personally what I would do- I wouldn't convert the harness over just to run the stock P28 ECU.
  3. Jeef
    Jeef NO MA'AM Moderator VIP
    Stick with what you got.
  4. allmotord16rex
    allmotord16rex Senior Member
    Anderson, SC
    :withstupid: The ZC generally has more low end and peak torque than a d16z6. Mine dynoed at 104 ft lbs with just an intake. I would definitely stick with the ZC.
  5. Drenni
    Drenni Senior Member
    Is a good idea if he would just use the Vtec head and a conversion harness (obd 0 to obd 1) and run a chipped P28 keep the ZC block.. Is that considered a good mod or is it a waste a $$$$ Maybe it's better for him to do that instead swaping the engine.
  6. phunky.buddha
    Waste of money... that's a DOHC ZC he has in there, not a SOHC ZC.
