tylonalsnifnfool
i am wondering wich would be better to put in my 90 crx si? which can i get more power out of in the long run without useing a turbo? The ZC is a way easyer swap to do right?
you can pull quite a bit of easy power out of the D16Z6 without spending too much money. One of the basic formulas is to up the compression to 12.0:1 with DOHC ZC pistons (PM7 or P29) that you can get for about $100, then add on an aggressive head and valvetrain. A typical cam for the SOHC VTEC will run you about $250-350, and matching valvetrain is only about $250 more.
I was planning a similar build for my CRX. I was going to use a SOHC ZC block, DOHC ZC pistons, P&P Z6 head, and Crower Stage 3 cam + valvetrain. A VAFC would have been used to tune. Overall it would have cost me less than $1000 in parts (labor free with me in my garage), and I would have been looking for about 160-165whp. Torque would have been in the vicinity of 115lbft to the wheels.
Something like that would make quite a peppy little engine for not much cash at all.
i would like to do somthing like that. BTW thats from Calesta
