ZC Pistons a no-go?
Discussion in 'HYBRID -> EG-EK / DC' started by Havok, Oct 4, 2002.
  1. Havok
    Havok Senior Member
    Florida
    I was thinking about ZC pistons in my D16Z6 head swap, but I head they break down at around 180 hp--any other suggestions? I wanted to get them for higher comprerssion ratio.
  2. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    are they even compatible? wouldn't you have to get custom rods and stuff for that? I would advise against it just for the PITA factor..I mean you wouldn't be raising your compression any more than .5 or so..if you are gonna build for high horsepower then do it right the FIRST TIME. Don't buy stock internals designed for stock HP numbers..SRP makes 3 sets of 10.5:1 pistons (depending if you want to bore it over or not) for the D16Z6.
    --You said head swap..what block are you swapping onto?
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Yes the ZC and Z6 pistons are compatable! Don't use the stock ZC pistons. Get some aftermarket ones! Trust me.
  4. Havok
    Havok Senior Member
    Florida
    it's a D15B7/D16Z6 head swap, what are some web sites for some good pistons?
  5. slohnda
    slohnda Senior Member
    Sierra Vista, AZ
    http://www.jepistons.com
    check out the srp's..
  6. lelopez
    lelopez Junior Member
    SRP's are garbage in my opinion........go with the new Wiseco IB pistons or the Endyn/Wiseco pistons.
    go to honda-tech.com and pm b18bturbo (Viren). He can get you a set of these pistons really cheap. Tell him I sent you.
    later,
    Lester
  7. stpracer
    stpracer Senior Member
    Grove City, Pa.
    I have SRPs and I hate to be disagreeable but they were a lot of money for a piston that is just OK. The fit is not as tight as stock. If I had a do over I'd buy others.
  8. phunky.buddha
    Dallas / Fort Worth, TX
    Same thing...
  9. Havok
    Havok Senior Member
    Florida
    ok, thx I'll prolly get the Endyn
