zc question
Discussion in 'Civic and CRX - EF' started by lizoyd18, Dec 20, 2006.
  1. lizoyd18
    lizoyd18 Junior Member
    im thinking about getting a zc.. my question is will i need alot of parts for it???ive researched and it gives diffrent information... i have a 90 civic dx any info will be nice thanks
  2. K20-R EP
    K20-R EP New Member
    Beirut, Lebanon
  3. lizoyd18
    thats where i get confused they say i have to rewire on here it just say i just need another ecu and odb0
  4. drnenappes
    drnenappes Mr Nissan Geek
    Twin Cities, MN
  5. K20-R EP
    K20-R EP New Member
    Beirut, Lebanon
    why don't u just use an si ecu if you can't get the zc?
    with the si the car will be a little rough tho...
  6. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    If hes got a dx model crx, he still needs to wire the car for mpfi. The dx was the only model to use the dpfi and you must convert it before using the pm6 (si comp) or pm7 (zc comp) or pg7 (integra comp).
  7. lizoyd18
    ok i get it ill just cut the ones i dont need and go from there thanks for the help....... is connector c is for the distributor???
