I've got a DOHC ZC that I'm building to stock specs also. I just ask for D16A1 parts which was in the 88-89 Integra I believe. I've attached a post that a guy sent me on thezcr.com forum. Might help you out.
ZC PARTS LIST
Alternator
Belt 88-91 crx/civic
A/C Belt 88-91 crx/civic This is for a DENSO
compressor but yours may
be different
Timing Belt 88 Prelude
2.0 SI
Engine
Mounts 88-91 crx/civic Do yourself a favor and
replace them. They'll be bad
Thermostat 88-91 crx/civic
Crank Seal 89 integra 80x10 mm
Rear Main
Seal 89 integra 31x46 mm
Cam Oil
Seals 89 integra need 2 seals
Valve
Cover
Gasket 89 intetgra
Radiator
Hose -top 84 accord
lower 88-91 civic/crx
Distributor 89 integra
Cap & 88-91 crx/civic
Rotor
Exhaust 89 integra
Gasket
Water
Pump 88-91 crx/civic
Oil Filter 88-89 integra
88-91 crx/civic
Spark Plug
Wires 89 integra
Throttle body 89-91 crx/civic
& TP Sensor 88-89 integra with the d16a1 motor
ECU (OK) 89-91 crx/civic SI
ECU
(Better) 88-89 integra (must be 5 spd Ecu)
ECU
(Best) 89-91 ZC (112 mph speed limit)
Spark Plugs 88-89 integra
88-91 crx/civic
Head Gasket 89 integra
intake gasket 89 integra
exhaust header 88-91 crx/civic ( need to be port matched with
with a dremel)
oil pan gasket 88-91 crx/civic
Cam angle Sensor 88-89 integra
Distributor 88-89 integra
ZC PARTS LIST
Alternator
be different
2.0 SI
Engine
Rear Main
Cam Oil
Valve
Cover
Gasket 89 intetgra
Radiator
Hose -top 84 accord
Rotor
Exhaust 89 integra
Gasket
Water
88-91 crx/civic
Spark Plug
Wires 89 integra
ECU
ECU
88-91 crx/civic
with a dremel)
