zc serial number help
civiicek9
well im tryin to figure out which version zc i have so i can fix my sputtering problem, unless all versions use same parts, but anyways, ive read threads stating that serial codes starting with "2" are the crx si and the "5" is the integra, but my zc starts wit 6, does that mean its still from the integra but they started the next number in sequence
Im not sure why you are going off of the serial number. Do you have a DOHC Black top ZC? Or a SOHC ZC? Check out thezcr.com they have a couple of documents detailing what replacment parts for your ZC you need.
