zc/si hybrid
Discussion in 'HYBRID -> ED-EF / DA' started by thiebert, Apr 13, 2005.
  1. thiebert
    thiebert Senior Member
    Vancouver
    I am doing a ZC/Si hybrid tranny with zc 1-4 si final drive. i want to use my si differential so that i dont have to mess around tring to find out what cv shafts will fit the ZC one. However, my si tranny input shaft bearing is shot i think (i haven't got it apart yet. but it rattles really loud at about 1200 rpm. in neutral, 1-5 doesnt matter what gear clutch in or out still doesnt matter. it always rattle loud at that rpm then stops above or below it.) I was wondering if it would be a better idea to use the zc housing and put the si diff and final drive in that or put the input shaft and 1-4 into the si housing? thanx guys
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    providing you have the same spline count on both mainshafts, i would use the ZC case with the ZC mainshaft, swap all of the ZC countershaft gears onto the Si countershaft and drop the entire Si differential in - use the ZC shift forks - be careful when removing the synchros from the countershaft to keep the synchro hub and sleeve together when you pull them off the shaft - they only go together correctly one way
