ZC SOHC build
Discussion in 'HYBRID -> ED-EF / DA' started by jay di em02, Aug 8, 2007.
  1. jay di em02
    jay di em02 New Member
    I was wondering what i could to do my SOHC ZC to make it gain the most power...Cams, Pistons, etc...I've been searching, but i just want some opinions and thoughts about it...Also i'd like to be relativaly cheap here but with no turbo =]
    thanks.
  2. Ryma
    Ryma Member
    pick 2
    power, cheap, reliability.
    Get a turbo kit and a tune for cheap reliable power.
  3. droolguy
    droolguy New Member
    Chico, CA.
    Turbo & Tune?
    First, he said no turbo.
    Second, I guess you would have to define cheap, considering thats going to run like 2k+ between the kit and paying someone for an ECU tune.
    We need to know how much you want to gain from the setup, and how cheap you want it to be, and if by "no turbo" you mean no forced induction at all.
  4. droolguy
    droolguy New Member
    Chico, CA.
    You could buy one for 1.5 but your not looking at very high quality. Good enough to run 9psi all day though if you don't want to do any internal work.
    So I suppose with the criteria you would be right, cheap and it'll net him a good amount of hp.
  5. jay di em02
    Well i want the car to be N/A. I just want to build the motor little by little, but whats the best thing to get in it first besides headers, exaust and intake.. thanks for the replies.
  6. droolguy
    droolguy New Member
    Chico, CA.
    N/A is far from cheap if you really want to build some hp.
    I really don't build N/A that much but the general idea is to jack the compression up as high as you can get it and the parasitic loss as low as possible, while maintaining excellent flow dynamics. The drawbacks to N/A is you will ONLY run high octane fuel (like alcohol) once you build it past a certain point. Also, it is a lot of custom fabrication.
    One plus though, it is a lot harder to break a N/A engine.
    As far as parts go, if a more experienced N/A builder doesn't reply I can point you in the right direction.
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    P29/PM7 pistons, Bisimoto camshaft/valvetrain and header, ported intake maniofld+larger throttle body, and tune. That right there is under $2000, with the bulk of the cost coming from the Bisimoto components. You can get cheaper camshaft(like a regrind from Delta for about $75) and spend some money elsewhere.
    btw, the highest HP all-motor D-series and F-series runs off of pump ;)
  8. jay di em02
    sounds good rite there, how much will that stuff be raising the hp?
  9. jay di em02
  10. droolguy
    droolguy New Member
    Chico, CA.
    Just in case this was a crack at my comment...
    Never said compression alone was a way to make power...
    And a gt20 should fit a stock ZC quite well for under 1500...
    If its true then I stand corrected, like I said I don't build N/A much.
    P.S. If it sounds like i'm on the defensive its because I am... people picking apart my posts, or I am just paranoid. Probably the latter.
  11. droolguy
    droolguy New Member
    Chico, CA.
    Had to check, I get an itchy trigger finger when I join a new forum, don't know the people.
